I'm new to computers, so I had a friend who knows a little more than me help with this.
https://pcpartpicker.com/list/BdTpd6
1. Budget & Location
Max budget is $1300 and I'm located in the US.
2. Aim
I plan on using the system for gaming with friends (probably some PUBG, Overwatch, CS:GO, and modded Minecraft). I also plan on using it to try out 3D modeling and coding which I heard can be CPU intensive.
3. Monitors
Probably just the one listed.
4. Peripherals
Windows 10 (my friend says that its cheaper because I just need to buy the license since he has the USB) and the keyboard/mouse listed.
5. Why are you upgrading?
Because all I have now is an old laptop and I want to have something that can run intensive programs without becoming super slow. I also am really interested at looking into coding and computer science.
Would this work or do you have any recommendations?
https://linustechtips.com/topic/879273-first-time-building-a-pc/
Maybe just get a 1600 non x and get your friend to help you overclock
You NEED to add an SSD
imo I would spend the extra bucks to buy a better keyboard and mouse.
I agree with Slottr  you nEED an SSD.
That motherboard has an m.2 slot, so look at an m.2 ssd, they are a little more expensive,
But they are MUCH Faster.
 Beowulff83, is also correct, Make sure that your ram works with the Mobo. I have had to help a few Friends, when they bought 2 packs of ram and then wondered why they didn't work together.
Might also want to look at a slightly better PSU, It's okay, but they last longer if you give them more lee-way in capacity. and it will allow for better upgradability.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($197.28 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($73.98 @ Newegg)
Memory: GeIL - EVO SPEAR 16GB (2 x 8GB) DDR4-3000 Memory  ($175.99 @ Newegg)
Storage: Crucial - BX300 240GB 2.5" Solid State Drive  ($74.99 @ Amazon)
Storage: Toshiba - 1TB 3.5" 7200RPM Internal Hard Drive  ($42.19 @ OutletPC)
Video Card: Zotac - GeForce GTX 1070 Ti 8GB Mini Video Card  ($449.99 @ Amazon)
Case: NZXT - S340 (Black) ATX Mid Tower Case  ($54.99 @ Newegg)
Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply  ($29.99 @ Newegg)
Monitor: Lenovo - L24q 23.8" 2560x1440 60Hz Monitor  ($159.99 @ Amazon)
Keyboard: Cooler Master - Devastator II Wired Gaming Keyboard w/Optical Mouse  ($24.99 @ Newegg)
Total: $1284.38
Generated by PCPartPicker 2017-12-30 01:09 EST-0500
