get a corsair CX/M, vengeance or be quiet pure power 10 instead of the M12ii, and that's about it.
https://linustechtips.com/topic/876198-help-gaming-pc-build/#findComment-10849209
2 minutes ago, Nelson Pereira said:
Is this Corsair CX650M 650W 80 Plus Bronze Modular ok?????
Yep that should be plenty of power.
Current System Specs:
CPU: Intel I5-7660K; CPU Cooler: Coolermaster Hyper 212X; Thermal Paste: IC Diamond 7 Carat; Motherboard: MSI Z270 Gaming Pro Carbon;
RAM: Kingston HyperX Fury Black 16GB (2 x 8gb) DDR4 - 2400; SSD Storage: 1TB Samsung 850 EVO; Storage: 2TB Seagate Barracuda 7200rpm;
GPU: Gigabyte Geforce GTX 1070 8gb G1 Gaming; Case: NZXT Phantom 530 Black; PSU: EVGA Supernova G2 650W 80+ Gold, OS: Windows 10 Home
https://linustechtips.com/topic/876198-help-gaming-pc-build/#findComment-10849221
yes.
https://linustechtips.com/topic/876198-help-gaming-pc-build/#findComment-10849229
1 hour ago, Nelson Pereira said:
The i7 8700 > 8600K IMO, hyperthreading is probably better to have overall than a 700mhz advantage.
https://linustechtips.com/topic/876198-help-gaming-pc-build/#findComment-10849458
Depending on the game, idk too many games that utilize HT and having a higher base clock may prove useful in certain games.
https://linustechtips.com/topic/876198-help-gaming-pc-build/#findComment-10849629
But do you really need another 10-20fps when you're already at 4.3ghz all cores on the i7?
https://linustechtips.com/topic/876198-help-gaming-pc-build/#findComment-10850392
