Hi guys,
I was trying new asus monitor 144 hz on my laptop now i can't play anymore on my laptop screen i get huge screen tearing now cant play normal on player unkown battle ground without v-sync off i must now activate v-sync, when i put the asus monitor back it works fine with v-sync off, please help me guys why is this happening now.
Specs Msi gt70
Gtx 970m
Intel i7 4700mq
8gb ram
250 samsung 850 evo
1tb
https://linustechtips.com/topic/874279-screen-tearing-help-me/
Just now, TDU said:
Nvidia driver?
Also that. If you open the windows menu and search Device Manager it opens a window where you can see all your devices in your system. Find the Monitors dropdown and click the down arrow. There should only be one device under it. After that right-click and click Update Driver. In the window that pops up click Browse my computer for driver software. Then click Let me pick from a list of available drivers on my computer. Then pick the driver that has the display name and click next. After that you should be done. I would also suggest that you reinstall you nvidia display driver.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/874279-screen-tearing-help-me/#findComment-10831637
I tested other games i can play smooth i think i must reinstall
I tested other games i have no problem with v-sync off i think must reinstall the game.
https://linustechtips.com/topic/874279-screen-tearing-help-me/#findComment-10832075
Well if it's only one game you should probably reinstall then :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/874279-screen-tearing-help-me/#findComment-10832110
