uninstall the GPU driver completely, reboot, download latest driver, and reinstall.
Plug the gpu to another pc see if problem exist.
Or plug another gpu (your friend's) to your system.
check the temp with CoreTemp see if its ryzing (pun intended) to 80c and above.
The normal is 60c at full load.
Order of test : GPU > MEMORY > Motherboard.
