I'm looking at high end bluetooth headphones and the only two that I can't decide between is the Sony 1000XM2 and the Sennheiser PXC550.
I know the Sony is quite a bit better but the downside is it comes with an entire year less warranty and its 60$ more expensive.
Would you guys go the Sony even without that year of warranty?
Sennheiser: $389
Sony: $449
Prices in AUD
https://linustechtips.com/topic/870250-wireless-headphone-options/
Sennheiser: $389
Sony: $449
Prices in AUD
Ive had both of them, the sony are far superior when it comes to the noise cancelling and all of that, so I would consider thoose rather then the pxc 550. If the warranty is your concern I would say, just as long you don´t treat eaither off them like shit, they wont break. Thats the deal with any headphone.
