I'm thinking of building a pc with a 3570K and wondering if anyone knows if an Asrock Z77 extreme4 would fit high profile RAM with a CM Hyper 212 EVO? If it doesn't fit would it be a good option to use the stock cooler and then get a h60 later. I'm also open to suggestions for coolers of the same price range and performance
as the hyper 212 EVO.
Main rig:
• Ryzen 3600X • X370 Killer SLI • 16GB Corsair LPX 3200Mhz • Strix 1070ti • Define R5 • SuperNova 750 G2 • Evo 1TB + X300 4TB •
Secondary rig:
• Acer prebuilt • Rzyen 1700X (upgraded) • OEM 1060 3GB • 256GB SSD + 1TB Seagate (upgraded) •
https://linustechtips.com/topic/8691-3570k-cooling/
Definitely enough clearance man.
You might not be able to see two of the RAM sticks under the CPU heatsink, but they will fit.
Although how high-clearance we're talking about I'm not sure. Could you provide me with the specific RAM model?
The ASRock Z77 Extreme4 + 3570K are great choices, have them myself. I have a very similar cooler and my G.Skill RipjawsZ fit fine :)
https://linustechtips.com/topic/8691-3570k-cooling/#findComment-97055
I'm thinking of getting these Crucial Ballistix Elite 2x4GB 1866MHz CL9 RAM because it's really cheap £43 which is 50€ or $65 but so big. I'm from Finland so i shop at Amazon UK. Soooooooooooo great prices.
link: http://www.amazon.co.uk/gp/product/B006TB4ZXC
Main rig:
Secondary rig:
https://linustechtips.com/topic/8691-3570k-cooling/#findComment-97111
I am a huge fan of closed loop cooling, very easy and very effective! Personally, i would stick with the stock cooler (and no overclock), and get a closed loop system asap! :)
How many GHz do you think you'd get out of a 3570K with a H100i
Main rig:
Secondary rig:
https://linustechtips.com/topic/8691-3570k-cooling/#findComment-97131
That is pretty nice :)
Main rig:
Secondary rig:
https://linustechtips.com/topic/8691-3570k-cooling/#findComment-97175
I think you SHOULD be okay, but I can't find any measurements so I cannot say for sure. Honestly, I would say stay safe and look at some low(er) profile RAM.
Mine fits with about 10mm to spare and it is not as high profile as the Ballistix.
https://linustechtips.com/topic/8691-3570k-cooling/#findComment-97394
Well I'm probably gonna go with some Corsair vengeance 1600MHz RAM cause it says it is really overclockable. And if you can't trust Corsair I don't know who you could trust. Linus'es videos have taught me Corsair = quality + Good value. Thats why I'm going to use a Corsair PSU, case, RAM, CPU cooler and maybe fans if i can ever afford them. Corsair FTW
Main rig:
Secondary rig:
https://linustechtips.com/topic/8691-3570k-cooling/#findComment-97966
Vengeance memory is excellent, but overclocking it won't really net you more performance.
Otherwise, that'll fit fine and that memory is excellent.
https://linustechtips.com/topic/8691-3570k-cooling/#findComment-98048
