yes
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/868819-cable/#findComment-10780532
As far as I know, there's a VGA D-sub connector for graphics card to monitor, and pcie cables, which are 8, 6+2, and 4+4 pin.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/868819-cable/#findComment-10780533
The PCIE power connectors are occasionally labelled with "VGA".
BTW 4+4 is EPS (CPU power, not PCIE power).
PCIE power connectors are of the form 6, 6+2, and 8.
CPU power connectors are of the form 4, 4+4, and 8.
PSU Tier List | CoC
https://linustechtips.com/topic/868819-cable/#findComment-10780539
P.s. 4+4 is EPS (CPU power, not PCIE power). PCIE power connectors are of the form 6, 6+2, and 8.
You're right, I thought I remembered my old PSU having a 4pin pcie connector.
Daily Driver:
Gaming PC:
https://linustechtips.com/topic/868819-cable/#findComment-10780563
Maybe you're thinking of molex.
PSU Tier List | CoC
https://linustechtips.com/topic/868819-cable/#findComment-10780567
Definitely not. I remembered using this in my old Dell:
Daily Driver:
Gaming PC:
https://linustechtips.com/topic/868819-cable/#findComment-10780589
