You could try a CMOS reset to see if solves the issue.
CPU: Ryzen 7 2700x, Cooling: Corsair H100i Platinum AIO MOBO: Asus Strix B450 F GPU: Gigabyte GTX 1080 Founders Edition + Arctic Accelero Xtreme III RAM: 2x8GB ThermalTake ToughRAM White 3200MHz PSU: Corsair RM850x White Storage: 250GB Samsung 970 Evo NVMe CASE: Corsair 275r Airflow White OTHER: White and Orange Cable Extensions ---- MONITOR: Samsung LC32JG5 32" WQHD 1440p VA 144Hz
https://linustechtips.com/topic/867213-cpu-and-dram-led/#findComment-10766417
4 minutes ago, cs95 said:
I've tried that.
Next time quote or tag if you want faster replies ;)
So after the CPU led turns off and the RAM led turns on what happens. Does the RAM led stays on?
If yes:
1. Try with a single stick of ram if you have multiple.
2. Even though you checked the CPU is seated correctly, please remove the cooler and check the CPU contact surface with pins to be clear and also check the socket pins for debris or bent pins (if Intel CPU)
I had the same problem and from personal experience I can say that if there are no problems with CPU socket at all or RAM slots or RAM and CPU by themselves then is the chipset that might fail. This might sound extreme and hard to believe but it's a possibility, happened to me twice so far.
Also what motherboard do you have?
https://linustechtips.com/topic/867213-cpu-and-dram-led/#findComment-10766445
If yes:
After the ram led goes off the cpu led comes back on and then goes off and the ram one comes on again. No pins are bent and the cpu + socket look fine. I have a msi Z170 g43 plus
https://linustechtips.com/topic/867213-cpu-and-dram-led/#findComment-10766586
