triple moniters help
Solved by Glenwing,
Just now, Brett_UK said:gong by that i wouldnt be able to use them on deasktop for apps like youtube and coding etc and just have the main moniter for games ? i just couldnt use them all in games at the same time ? or best to just get all 1440p moniters ?
You just won't be able to use them in NVIDIA Surround to span games across multiple monitors, you can still use them all on the desktop just fine.
