Dears,
this is my first build, i have got the below items, can you tell me what's remaining except for CPU, GPU and RAM ? is there any fans, cables,... etc missing ?
also do i need to buy thermal material for the CPU cooling ? i will use xeon e-5 1660 V4
Thank you,
https://linustechtips.com/topic/866485-first-build-need-advice/
What CPU/GPU/RAM are you getting? also 1600 Watt is overkill for almost anything
PC Specs:
CPU: Intel Core i7-8700k @ 4.7GHz Turbo
Motherboard: Maximus X Hero (Wi-Fi AC) LGA1551 (300 Series)
RAM: 2x8GB Trident Z RGB DDR4-3200MHz
GPU: Gigabyte G1 Gaming GTX 1080
SDD: Samsung 850 EVO 500GB
HDD:  Seagate Barracuda 2TB
PSU: Corsair RM650x
Cooling: Corsair H115i Pro RGB
OS: Windows 10 Pro (Un-Activated Currently)
Main Display: Dell S2417DG 1440p 144/165Hz G-Sync (2560x1440)
Secondary Displays: 2 x Dell P2312H 1080p 60Hz (1920x1080)
Keyboard: Corsair K95 RGB Platinum
Mouse: Logitech G703 Lightspeed Wireless Gaming Mouse
Headset: Massdrop x Sennheiser PC37X Headset
https://linustechtips.com/topic/866485-first-build-need-advice/#findComment-10758583
  • 3 weeks later...
This question can only answered by a very niche selection of the community. Honestly I must say good luck as I have no idea how to balance Xeon/Epyc-class builds.
??? Wanna join ??? my free??gift card??? giveaway??? Click ⤵ the subrscribe button?? ,turn? the notifications on ??? and finally leave a nice comment ??down below⬇⬇ , now without further adue ??? lets get on?? with the video▶▶
https://linustechtips.com/topic/866485-first-build-need-advice/#findComment-10843289
