"My problem is when I OC"
Hi, I recently bought a new pc with the following parts:
-Ryzen 3 1200
-Msi b350m pro gaming BIOS(version 2.7)
-2x4GB ddr4 2666 MHz ram
-Gtx 960 2GB
-240gb SSD
-EVGA GQ 650
I have tried the boost to 3.5GHz, OC to 3,7 at 1,275V and 4GHz at 1,35V. all these were stable. But then I shut down my pc and turn it on again after maybe an hour, it runs at 1,3 GHz.
The only troubleshooting that has worked for me is to reboot - back to auto (3.1GHz) - turn the pc on - reboot again to do the OC, and it works...
I haven't been able to spot people on the internet with similar problems yet, so know I'm writing to this community because I believe that there are some pro dudes here :)
https://linustechtips.com/topic/866418-ryzen-3-1200-oc-problems/
-Ryzen 3 1200
-Gtx 960 2GB
-240gb SSD
-EVGA GQ 650
I found out there could be a bug with the CPU multiplier, and someone suggested me using another program for OC. I now use MSI command center for OC and it works, I haven't (yet) discovered any problems.
but I will try this out for a week maybe, and come back to tell if it's solved :-)
my OC now is 3.8GHz stable at 1.275V
