So after installing my new Gigabyte RX580 8GB Aorus edition my system started to restart when I play games like CoD:WW2 or Watch Dogs 2. It stays in game for cca 15-20 minutes, and then it restarts back. Im running the latest version of WIN10, and the latest version of AMD Drivers.
I was watching that it could be a PSU Problem, but im running Corsair CX 750M, and I think that I can remove that from equation. The GPU nor the CPU are not overclocked.
https://linustechtips.com/topic/865910-rx580-problem/
You might also have dirty power coming from the wall but its unlikely as that would be more inconsistant with shutdowns, but maybe combing that with a higher load would do it.
Ive had dusting out my powersupply help. As well as turning off other high power appliances running off the same breaker.
https://linustechtips.com/topic/865910-rx580-problem/#findComment-10753417
31 minutes ago, vinyldash303 said:
That sounds like something heat related. Does the fan spin up in your power supply? Is there dust clogging it up? Is the fan side down into carpet?
Fan does spin, and the fan is facing down to the wooden laminate.
There is only my computer, two lights and the fridge in the kitchen running in the whole apartment. And they are not connected to same breaker.
https://linustechtips.com/topic/865910-rx580-problem/#findComment-10753457
Alright probably isn't that then. Dusting the PSU can't hurt, but other than that I have no further advice. I'll leave the rest of the diagnostics to more experienced people. Best of luck.
https://linustechtips.com/topic/865910-rx580-problem/#findComment-10753489
