So I just got a laptop, fairly old I believe, the HP Envy 15-j100ni and I am trying to get it to run games such as overwatch, but whenever I do it drops down to less than 10fps consistently. Even on my "craptop" (3rd gen i3 and intel integrated graphics 4000) I would get more than that on minimum settings, where as my new system, with an i7-4700MQ @2.4GHz and the NVidia GeForce 840m even though I have all the latest drivers etc. Any tips or troubleshooting I can do to make it work as I believe it should as seen elswhere online?
https://linustechtips.com/topic/865061-problems-with-my-system/
https://support.hp.com/ca-en/document/c04470976
this one? make sure Overwatch is set to the Nvidia graphics card. you can do that in the Nvidia Control Panel. then it will destroy your "craptop" in framerates :)
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/865061-problems-with-my-system/#findComment-10745753
