Hi, this is my first post here (:
Currently planning out my first custom loop. And I'm stuck on what res and pump to get.
I was thinking of getting either the XSPC D5 Photon 170 Reservoir/Pump Combo or the Phobya Balancer 150 paired with the Swiftech MCP655. If they're are better options out there for around the same price ($170.00 AUD) please let me know.
Other parts chosen so far:
Corsair 750D
Asus Maximus vi hero
I5 4670K
Asus GTX780 DC2OC
Corsair Dominator Platinum 16gb 1866mhz
Corsair AX860
Samsung 840 EVO 250gb
WD Blue 1TB
As for water cooling I plan on getting:
Koolance 380i CPU
PrimoChill Advanced LRT 3/8ID 5/8 OD in red
Koolance VID-NXTTN GPU
Koolance Compression Fittings
As for radiators, I plan on putting a an Alphacool XT45 360mm in the top of the case. And in the front an Alphacool UT60 280mm.
Please tell me if I've done something wrong, I am new to computer building.
https://linustechtips.com/topic/86304-first-custom-loop-planning/
I think  you can just about get 60mm rad top if you want
not so quick on 60mm in the roof. depending on motherboard (ASUS Hero especially)
the 8-pin power plug will be in a very tight bind that will cause the 60mm radiator to put
extreme pressure on the 8-pin and cause the motherboard to be in a bind against the
radiator. the Rampage has a similar issue, but not as problematic as the Hero. i've
tried both along with others and they all seem to have the same issue with 60mm.
the 45mm is a breeze, but that last 15mm is/can be a deal breaker. even removing the
rubber grommets and off-setting the rad mounts 5mm would help, but the ODD cage is
impeding the progress. another corsair moment.
