1 minute ago, ImNotThere said:
a shoddy one
Have you used an intel stock cooler? they're actually not as bad as people make them out to be. The main problem with them is how loud they are.
It'll be fine for cooling this whilst gaming.
https://linustechtips.com/topic/861292-gaming-pc-build-advice/#findComment-10713581
my one experience was with a haswell i3 and the stock cooler struggled to keep the little dual core below 70 degrees
so imo, theyre awful
https://linustechtips.com/topic/861292-gaming-pc-build-advice/#findComment-10713589
I'd be tempted to say maybe it wasn't mounted right in that case. Either that or they've drastically improved the stock coolers performance since the haswell days.
https://linustechtips.com/topic/861292-gaming-pc-build-advice/#findComment-10713594
Probably a bad mount. Stock cooler on my 775 pentium dual core keeps it under 65 degrees while OC'd to 3.5 from 2.6.
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
https://linustechtips.com/topic/861292-gaming-pc-build-advice/#findComment-10713604
2 hours ago, RKRiley said:
You wont get the full 144hz unless you're playing games like CS:GO and Overwatch.
Other than that its pretty good. could probably get an EVGA G2/G3 powersupply for the same price, slightly better quality.
What if I upgrade to a 1080 instead of the 1070 ti?
https://linustechtips.com/topic/861292-gaming-pc-build-advice/#findComment-10713976
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($199.89 @ B&H)
Motherboard: Gigabyte - Z370 HD3 (rev. 1.0) ATX LGA1151 Motherboard  ($111.49 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($154.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($78.89 @ OutletPC)
Storage: Toshiba - 2TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Newegg)
Video Card: MSI - GeForce GTX 1080 8GB DUKE OC Video Card  ($514.98 @ Newegg)
Case: Cougar - MX330 ATX Mid Tower Case  ($34.99 @ Newegg)
Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply  ($24.99 @ Newegg)
Monitor: Acer - GN246HL 24.0" 1920x1080 144Hz Monitor  ($187.49 @ B&H)
Total: $1367.70
Generated by PCPartPicker 2017-11-18 10:59 EST-0500
https://linustechtips.com/topic/861292-gaming-pc-build-advice/#findComment-10714050
probably, if i still had it id give it another go
https://linustechtips.com/topic/861292-gaming-pc-build-advice/#findComment-10714069
