Laptop not using dedicated GPU
Go to solution Solved by The Oddball,
Disable the iGPU in Device Manager.
(of course select the iGPU, not dedicated)
This may reduce battery life, so I suggest turning it back on while not gaming.
Thank you. This solved my problem.
