i bought two 780 sff motherboards on ebay for a decent price
i had to trim some plastic from the cpu fan header so i could fit my cpu fan connector to it
the pc makes long beeps one after another i wasnt sure if the cpu was on since the fan didnt spin
but i confirmed that after touching the heatsink i have a normal fan and heatsink on it as it didnt come with one
is there any adapters for cpu fan headers?
https://linustechtips.com/topic/860420-dell-optiplex-780-cpu-problem/
Dell use a different pinout on there latching connector than the standard fan connector, since you have already modified your mobo to fit a standard fan connector all you have to do is pop the wires out of the fan connector and put them back in the right order. make your wires order the same as connector on left. yellow is white. if you have a 3 pin ignore blue pwm.
500x1000px-LL-eec9b1e1_pwmpinoutsmall.pn
hi thanks both i changed the wires around but im having a hard time finding the front panel pins to power on the system with a screwdriver
Looked up the beep codes for your board 4 beeps appears to be a memory issue;
first try re-seating the memory. remove memory, blow out slots,  wipe contacts on memory with dry paper towel.
if that does not help then try each stick individually in each slot and if possible try memory in different system and/or try new memory in current system to try and identify issue.
2 hours ago, SuperCloneRanger said:
I found the service manual for your board.
http://content.etilize.com/User-Manual/1029902242.pdf
thank you both for your replies sorry i couldnt reply my internet went off it was the ram i took it back to the shop and placed my other ram sticks in the slots booted up the only thing now is i need to find a cpu adapter
Just now, SuperCloneRanger said:
to fit the cooler to the weird mounting holes?
yeah right now im using zip ties but it went to crap because my graphics card gets in the way of the cpu a bit do you know how i can put a normal 775 cpu on there without it coming off? and also how to power it up would a 4 pin splitter do the job?
i tried changing the wires around but the cpu fan still doesnt spin?
You swapped pins 1&3? I am running Standard fans on an Optiplex 790 with the pin swap and it runs fine.
http://pinoutguide.com/Motherboard/dell_5pin_4pin_pinout.shtml
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
although not recommended thermal adhesive would probably work too, but once applied it is very difficult to remove.
http://www.arcticsilver.com/arctic_silver_thermal_adhesive.htm
as for the fan make sure it is wired correctly and make sure your putting it in the right way round the the 2 connectors are a mirror image of each other. if that dosen't work try a different fan
thanks for the reply i got my cooler on there with a zip tie i bought a dell cpu fan adapter which works but now im facing problems with my new ram i just bought today
they are two 4gb sticks i tried changing the clock speed to 1066 insteac of 1600 but nothing is working? im getting beeps
i've looked at the specs for you board and the 8 gb should work, the speed should not be an issue, the board should automaticly set the speed to 1066. first make sure your using the correct dimm slots, looking at the manual it is the white ones. then reset the cmos:
disconnect form wall
Remove coin cell battery from holder
Press the power button for at least 10 seconds
Re-insert coin cell battery
When the system is powered on, it will warn that the date and time is not set, indicating a successful reset.
also here is the correct manual for your board, not sure why google gave the the 760 docs when i asked for 780.
http://downloads.dell.com/manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-780_service manual3_en-us.pdf
i dont have white dim slots? they are all black? :S
i've not thought about memory density in a long time, but looking at this info i found on the dell forum you're right.
http://en.community.dell.com/support-forums/desktop/f/3514/t/19629648
your best be is to look for 780 specific memory or add low density when searching ebay/amazon. your unlikely to find this memory new as no one will be making it anymore. who knew it would be such pain to get a cheap dell board working.
i ordered 8gb of ram from ebay i think its low density it hasnt got any heatsinks so it should work hopefully it should be here tomorrow ill let you know if its all up and running :)
on a good note atleast my main rig will have 24gb of ram instead of 16 thats a plus
