Water Cooling Mounting Tips
Go to solution Solved by SwingLifeAway92,
Which res is it? Best solution usually is drilling holes in the case
Hey everyone!
   I’m building a pc in the Corsair 570x, and I’m going from mounting a reservoir with Velcro to something else. The question is, how would I mount a reservoir in this space without it looking tacky? (The space in front of the fans) Thanks in advance.
https://linustechtips.com/topic/858340-water-cooling-mounting-tips/
R7 2700x (4.3ghz), Gtx Titan Xp Galactic Empire (Watercooled), 2x8 Gskill Trident 3200mhz, Asus Crosshair VII Hero Wifi, Corsair 900D, SAMSUNG 960 PRO M.2 256gb, Samsung 850 evo 500gb, 4x3tb 7200rpm Segate Barracudas in Raid 10 EKWB Custom Loop, Corsair AX1500i Power supply
