For the past year or so I've had an intermittent "A disk read error has occurred, Press Ctrl+Alt+Del to restart" error on boot, and usually pressing ctrl+alt+del reboots into windows (or it takes 3-4 times to boot into windows).  The error occurs about 30% of the time I boot the computer it comes up with the error, and about 10% of the time the error comes up it requires multiple reboots to get into windows.
Full specs can be found here.
I have replaced the SSD and CPU since the error first started happening, and I have run memtest to rule out the memory being an issue.  I currently suspect that it is either the PSU or Mobo.   Has anyone had this issue before, or have an idea as to what is the cause?
AMD R9 5900X | Asus Strix RTX 2070 Super | 32GB Corsair Vengeance RGB Pro | Neo G9 | Full Specs
https://linustechtips.com/topic/857606-intermittent-disk-read-error/
