Hello i need mighty linus tech tips forum help
i bouth a new motherborad for 30 euro with is Fujitsu D2709-A13 and dual x5570 for 25 euro seams like a good build for playing games and doing school cooding. i need a good ebay or samthing like  that for cheap psu with 2x8pins  and 2x6pins for pci express i need atleast 650 watts power .and i need ram advice its seas in user manual that it suports (32Mx16-533 DDR2 SRAM for iRMC S2) is it really ddr2 compatable or is it just a server onborad starage. and i need new programs and advice all you can tell ,me tell.no hating please .
and is it ddr3 copatable tell me best cheap ram tu use i need atleaset 20 gb .
https://linustechtips.com/topic/857484-need-help-making-new-serverworkstation/
if it says DDR2, then it won't eat DDR3, not even when carving a little on the pins...
You won't really be happy with that thing if you also want to play games...
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
16 minutes ago, lemonmusicrocks said:
Ya, playing games on a server platform is not going to end well because of how slow the single thread performance is on those chips.
Better off reselling it and finding an old business machine or building an AM4 APU rig if your used market sucks.
but my old pc was phenom 965 not OC so server will be only a little bit slower right?
I have an similar board in my Workstation and your Board HAS DDR3-slots! For RAM I'd go for PC3-10600R because you can get it fairly cheap on ebay. I have 64GB in my machine, paid 40€ for 80GB used and tested.
Your CPU is comperable to an first-gen i7 so your gaming performance should be fine (if you can get away with playing games on Normal and not Ultra), I have two X5550 and my games (mostly GTA5 or Payday 2) run fine on high.
As for PSU: The best find would be to find the corresponding Fujitsu OEM PSU or some other Workstation OEM PSU, would be the cheapest way maybe.
Main Rig
CPU - i7 6700 | RAM - 16GB (2x8GB) G.Skill, 16GB (2x8GB) Crucial OEM | GPU - MSI GTX 980 Gaming | PSU - Cooler Master G450M | Storage - 1x 256GB Samsung SM951 (NVMe)(System), 2x 500GB Samsung 860 EVO (Striped) | Case - Fractal Design Define R5 (with TG side Panel) | OS - Windows 10 Pro
NAS / Docker Host
CPU - Xeon E3-1220v3 | RAM - 16GB (2x8GB) Kingston ECC | PSU - Enermax Revolution SFX 550W | Storage - 3x 4TB WD Red, 1x 2TB WD Red, 4x 3TB Seagate Constellation, 2x 250GB Samsung 850 EVO (Cache) | Case - AVID Unity Media Engine (3U Rackmount) | OS - UnRAID OS Pro
VM Host
CPU - Xeon E3-1246v3 | RAM - 32GB (4x8GB) Samsung ECC | PSU - Enermax Revolution SFX 550W | Storage - 2x 512GB Samsung 860 Pro (System / "Fast" VM's), 4x 500GB HGST (RAID 10) | Case - Avid Unity MediArray XT (3U Rackmount) | OS - Windows Server 2019 Datacenter
Notebooks
Fujitsu Lifebook E756CPU - i5 6200U | RAM - 8GB DDR4 OEM | GPU - Intel HD 520  | Storage - 250GB Crucial MX500 | OS - Windows 10 Pro
Apple MacBook Pro Mid 2015 | CPU - i7 4770HQ | RAM - 16GB | GPU - Intel Iris Pro | Storage - 512GB Toshiba XG4 NVMe | OS - macOS 10.15.1
You should really not waste any money on this system, your Phenom 965 really isn't the worst thing ever, but it's likely faster than a 2GHZ Xeon chip
i am thinkg of this psu MODECOM ATX 2.31 VOLCANO 750 GOLD  becouse used i hard to find thats for dual cpu and Fujitsu power suplays arent cheap. but its 100 bucks i will keep looking but if you find sum that are usable i will be happy if you tell me. thanke you for info on ddr 3 .i would like to run mac on this server one day dual boting windows
I highly doubt that will end well because of how picky OSX is with hardware
The EVGA GQ PSUs have 2 8 pin CPU connectors.
They aren't cheap indeed, thought you can get them for around 30€ used but i didn't find something under 100 either.
should be doable if the board has a Realtek network chipset and not Intel (which is hard to get running). I have macOS 10.13 running perfectly fine on my fujitsu OEM Workstation.
"How to hackintosh" is forbidden on this Forum but if you want to set it up on your board some time in the future just PM me ;)
Main Rig
NAS / Docker Host
VM Host
Notebooks
ok tnx.
