Spatial sound vs Headphone virtualization
7 minutes ago, willie420 said:
do i have this on or off. do i have it as well as Spatial sound or is it Headphone virtualisation vs somnic vs atmos??
You're sentence is quite hard to understand? I suppose you want to know if you should use Sonic or Atmos and how good are they compared to virtual 7.1 that's found in most headphones?
Main rig:
• Ryzen 3600X • X370 Killer SLI • 16GB Corsair LPX 3200Mhz • Strix 1070ti • Define R5 • SuperNova 750 G2 • Evo 1TB + X300 4TB •
Secondary rig:
• Acer prebuilt • Rzyen 1700X (upgraded) • OEM 1060 3GB • 256GB SSD + 1TB Seagate (upgraded) •
nope talking about this
I would turn disable all of the enchancements since I want to hear as close to what the producer of the audio wanted me to hear when listening to it.
I don't know about using the spatial sound. You could always try out if they do anything for the applications you're using. It's not like you're investing anything or couldn't just disable it if you don't like the effect
Main rig:
Secondary rig:
cheers cuz :)
