I need to connect 9 LL120 Series fans to the Corsair Commander Pro to control their fan speeds, via Corsair Link. It only has 6 fan headers, so I thought that I can connect 2 fans to it via a 2-way splitter, another 2 via a 2-way splitter, and 3 via a 3-way splitter. The other 2 will go in normally. I don't know what fan splitters I can control fan speeds with. Any splitter suggestions?
P.S. I'm not using the mobo fan software, because I'm controlling the fan RGB via Commander Pro and just want to keep everything together.
https://linustechtips.com/topic/855349-pwm-fan-splitters/
Just now, CyberFern0 said:
a hub? There are no splitters?
one input
multiple outputs, depending on it
a 'splitter', but with more 'logic' i guess
i haven't done any research / know anything about what i say though, so.. wait until someone else who knows this responds
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/855349-pwm-fan-splitters/#findComment-10652279
2 minutes ago, themctipers said:
one input
ok
Can you list the NZXT one?
https://linustechtips.com/topic/855349-pwm-fan-splitters/#findComment-10652286
ok
I think it's this one
https://www.nzxt.com/products/grid
https://linustechtips.com/topic/855349-pwm-fan-splitters/#findComment-10652291
