Need Help with home network layout
Go to solution Solved by Lurick,
10 minutes ago, titaniumshield said:
What am I supposed to do then? :|
Will this setup work?
Yah, it will work just fine as you have it in the diagram, no changes needed.
Get a nice 5 or 8 port gigabit switch and you're good to go :)
Hi everyone
Recently I build a few systems for my home like a home PC, Media Player and I have some future plans for the networking in my house in which I want to include a Media server. I have attached an image for reference of what I really want.
I was thinking of connecting an 8 port gigabit switch (for sharing between systems) to my router (100mbps max). That means I'll be using 5 ports in the gigabit switch for sharing between systems and 1 port for internet. I am concerned that the 1 port for internet connection might get saturated.
Will it be fine to set up this way? Please let me know how can I improve.
Note: I want this set up to be budget friendly as I don't want anything overkill.
My internet connection is 25Mbps
Gigabit speed for file sharing and media works for me.
Do check the image attached.
Thank You
Keep it simple.
https://linustechtips.com/topic/855182-need-help-with-home-network-layout/
I’d reverse the gigabit switch and the router placement, but keep the same pc/whatever else connected to the gigabit switch.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
Are you saying place the switch before the router and connected right to the internet?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
Yup
3 minutes ago, themctipers said:
Yup
That's a terrible idea.
The fact that any device connected to the switch will get an external IP and since 99% of residential connections are limited to 1 public IP, nothing else will get out.
Edit:
I see you made an edit, ignore my post as well :D
Prior Build Log/PC:
2 minutes ago, themctipers said:
Yup
Prior Build Log/PC:
Ohk, I just hope it doesn't saturate the one cable from the router to switch for internet too much. :)
Keep it simple.
Nah, if most of the stuff is going between devices connected to the switch then you won't even hit the link to the router
Prior Build Log/PC:
