I have the corsair lighting node pro kit and can connect any one of the 4 provided RGB strips to the node and they work, however once they are either connected to the first strip or strip,+extension cable, strip, the second or third RGB strip will not work at all. should be an obvious fix i would think? please advise.
https://linustechtips.com/topic/852698-corsair-lighting-node-pro/
ok added via + and no light on 2nd strips, i ran 1 strip pigtailed to second out of channel1 and did 1 strip extension cable 1strip out of channel 2 first strip out of both light but not either second also tried a restart, and disabling the reinabling so dunno issue :[
