onboard on/off + reset switch problem..
i use a screw driver to turn on my system i just complete the circuit on the front panel connection
here
http://www.youtube.com/watch?v=G4FOBL1c3pA
seems kind of dangerous..
As long as you dont touch anything but the pins, you should be fine
System specs:  CPU: AMD Phenom II x3 705e unlocked to x4 overclocked to 2.8GHz   |   MB: ASUS M5A78L-M LX PLUS   |   Cooler: Hyper 212+   |   GPU: MSI GTX 560ti OC to 910Mhz   |   RAM: 8GB PNY DDR3 1333   |   HDDS: WD Caviar Blue 320GB, Hitachi 500GB HDD   |   PSU: Cooler Master Extreme Power Plus 500W   |   Peripherals: Microsoft wireless mouse, old mac keyboard, ASUS VS238H, Gateway FPD2275W, some speakers, Logitech Driving Force Pro
It isnt dangerous.
Ive done it a ton of times.
Ive also seen linus doing it on the NCIX channel as well as the Linus tech channel.
okay.. i'll take your word for it, thanks!
