Hey guys, how you doin'?
First of all these are my PC specs:
OS: Windows 8.1 x64
Processor: i5-4440
Motherboard: B85-HD3
RAM: 12GB (1x Corsair Vengeance 8GB @1600Mhz + 1x Kingston HyperX Blu 4GB @1600Mhz)
Graphics card: Gigabyte GTX 760 2GB OC Ver 2.0
Bios Version: American Megatrends Inc. FG, 10/14/2014
It's not a problem anymore but I just wanted to know what was up with my PC.
Recently I discovered that one of my RAMs required 1.65V to run while my other RAM only needed 1.5V and although I read before that if I install 2 different RAM sticks with the same frequency they would run but it's not preferable but I did it anyways and that was like 3-4 years ago. I just had some extra money and went ahead and bought a WD Caviar Black 1TB along with a Corsair Vengeance 8GB RAM and I put it there and has been running fine since.
A couple of days ago I installed CPU-Z to check my DRAM frequency and found it it was running on something in between 1333 - 1600 Mhz. After I removed my case and blew the dust away I had to test both RAMs separately to see if there is a problem but there weren't any problems and they worked fine. I checked a couple of threads on multiple forums to see if it's okay to increase my RAM voltage to 1.65V because I don't want to damage neither my MOBO or my RAMs and also learned that they both run at different timings and they can't be the same so I kinda gave up and planned to buy another 8GB one later once I have the money cause' I hate to see my PC underperforming.
I put everything back and after I boot up my PC I quickly opened CPU-Z and surprisingly my RAMs are running on ~1600Mhz without changing anything in the bios settings. I went ahead and played a game of "PUBG" with my friends and surprisingly the game was way smoother than before as it hasn't been running smoothly at all since I installed it and thought that my PC specs are just bad and I just need an upgrade. Like literally the FPS doubled in PUBG and I don't even experience the same FPS or stutters I had before. I went ahead and opened up another game - CS:GO - and my FPS was way higher than before and again I am not experiencing any stuttering or FPS drops and my FPS kinda doubled.
My question is: What was wrong with my PC that made almost all the games run with such low performance? I cleaned my PC before and nothing happened or changed and I always clean my case from the dust every now and then to avoid any cooling issues since I live in a very hot country and I don't have anything other than the stock fans.
What was wrong with my PC all that time? could it be the RAMs? was my PC bottlenecking or something?
I have been trying to figure out what was wrong with my PC but I just can't figure it out.
https://linustechtips.com/topic/850382-troubleshooting-a-fixed-issue/
Just now, Dutch-stoner said:
Don't know if it would even have an impact, but maybe you switched the sticks position, or used different slots? Strange thing still.
I think I did change the sticks position. Would that have any impact? Not sure if I actually used different slots. Didn't pay attention.
