6 minutes ago, PrithwidipSaha said:
Is anyone here using Deepcool Assassin 2 on an AM4 motherboard if so can you please tell do I really need the upgrade kit for the AM4 socket ?
yup unless you have an asus motherboard that has the am3 holes as well as the am4 ones. they aren't spaced the same
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/847598-am4-socket-issue/#findComment-10568603
