6 minutes ago, COUPER MILLAR said:
a lot of it comes down to preference. Personally I set rads as intake with fans in pull as i feel this leads to less dust packed into the fins over time.
Yea im haveing the rad on the outside of the case really like the look with ek vardar fans on intake
https://linustechtips.com/topic/847495-attaching-fans/#findComment-10567283
Put the screws through the fan then the case then into the rad. Pretty standard.
https://linustechtips.com/topic/847495-attaching-fans/#findComment-10567428
