So, I got the following:
B350m bazooka
R3 1200
Gtx 660(borrowed until my 970 arrives)
Tx550m
8gb corsair vengeance lox
I just finished installing win10, was searching my bios to get it updates but while I was  just browsing the internet my system shut down, everything, except the 660 my friend was using in his system is brand new, the mobo debugger says my gpu is not recognized or it is flawed what should I do?
https://linustechtips.com/topic/847490-help-new-ryzen-system/
By any chance, have you attempted trying a different Power Supply? Just to confirm that you do not have a bad PSU? If the problem continues with another power supply, try running memtest to make sure that you do not have faulty RAM.
Also, even though the card may be brand new, you could have a faulty GPU.
https://linustechtips.com/topic/847490-help-new-ryzen-system/#findComment-10567226
The system won't turn on now, so I cant run any tests, the mobo haa one of thoose led indicators saying which part is faulty and it only points out the gpu , dont have an spare psu :(
https://linustechtips.com/topic/847490-help-new-ryzen-system/#findComment-10567247
Ryzen does not have APU.
reseat the GPU.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/847490-help-new-ryzen-system/#findComment-10567279
