How to split-view PDFs in Foxit Reader
Go to solution Solved by unknownmiscreant,
There is. View --> page display--> vertically split
I don't like carrying my math textbook home, so I use a PDF version I found online and downloaded. When I need to look at the question and the answer at the same time, however, I have to open two separate windows. Is there any way to split view in Foxit Reader (like how can view two parts of a document in one window in Word)?
Night Fury 2.0:
Intel Core i5-6500 / Cryorig H7 / Gigabyte GA-H170-D3H / Corsair Vengeance LPX 8GB DDR4 @ 2133MHz / EVGA GTX 1070 SC / Fractal Design Define R5 / Adata SP550 240GB / WD Blue 500GB / WD Blue 1TB / EVGA 750GQ
Daily Drivers:
Google Pixel XL 128GB / Jaybird Bluebuds X3 / Logitech MX Master / Sennheiser HD 598 /
https://linustechtips.com/topic/845903-how-to-split-view-pdfs-in-foxit-reader/
There may well be. I think I did a similar thing in the past. Can't remember the exact steps though.
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
Main rig:
Crosshair VI Hero
EK Supremacy Evo
Asus Strix Soar
Laptop:
Dell E6430s
16GB 1600MHz DDR3.
