So I'm trying to dedicate one of my GPU's (GT 1030) to OBS Studio. It works really well in OBS Classic when I select the GT 1030, just doesn't work with OBS Studio. According to my research the GT 1030 has the ability to use NVENC encoding (which I also tested in Classic and works). Then again when I select "GPU 1 in OBS Studio under the NVENC setting at fails to start recording.
So why would OBS Classic work but OBS Studio not. What bothers me more is I found some videos that claim the GT 7xx series through the gt 10xx series don't have encoders. Do I need a GTX??
https://linustechtips.com/topic/845703-obs-studio-obs-classic/
46 minutes ago, Mythical Knights said:
i kinda figured. still seams weird that it works great in OBS Classic
Studio is the open source version meaning the community works on it and builds it together.
I hope you can find a fix elsewhere, if not maybe requesting it on obs will help you get the feature added.
https://linustechtips.com/topic/845703-obs-studio-obs-classic/#findComment-10548868
