4 minutes ago, NotTheRelaxngEnd said:
the b250m provd is really good
3 minutes ago, NotTheRelaxngEnd said:
unless you need an overclocking or sli/crossfire capable motherboard
in case youdo those are the higher end and are about 200 usd, but irst what cpu and gpu do you want to use
https://linustechtips.com/topic/843939-help-find-motherboard/#findComment-10530184
since i want to help you heres a easy thng to do that should help you, go to (pcpartpicker.com) qnd choose browse by indivdual parts, then lok especifically for what you want,scroll down and filter what you want, socket,color,pcie slots,overclock support,form factor, ram, etc. its pretty easy to use and will help you see if parts are compatible
https://linustechtips.com/topic/843939-help-find-motherboard/#findComment-10530194
Just now, NotTheRelaxngEnd said:
i cant really tell you right now, its2 am where i live and  have to sleep , but if you go to pcpartpicker you should find something, it browses the best pries in reputable stoes like amazon, newegg, b est buy etc.
Newegg is for usa, im talking about european sites, amazon.de had nothing cheap.
https://linustechtips.com/topic/843939-help-find-motherboard/#findComment-10530203
o hyes rheres a location feature at the corner
that should do the trick,also make a lst of what you nee, yull see any incopatibilities before purchase, now the thing you cannot chec is if the cooler will fit or if the ram or whatever
https://linustechtips.com/topic/843939-help-find-motherboard/#findComment-10530217
