Upgrade wifi card?
Go to solution Solved by ErrystioT,
You first need to check whether your laptop supports the NGFF M.2 form factor or the HMC (slot like mSATA, but 1/2 the size). Regardless, it should be upgradeable.
Hey guys,
I have a laptop that was manufactured back from 2013. It has 8gb ram, and an i5-3337ui cpu in it. It works great for me and I plan to use it until the plastic body finally gives up. In case you were wondering the make is a Sony Viao and runs Windows 10.
I currently live in a studio apartment and the 2.4 wifi here is terrible. My cousin just recently purchase a new laptop that does 5.8ghz and he has great wifi. Soo, the option is to pay $15 every month to have ethernet wired our room or I could invest in a better wifi card.
My only reservation is whether it easy or seamless to add a 5.8ghz card to my laptop. Would I need to switch out the antenna or something like that or simply pull the back cover and pop in a compatible card. It would be great if that were the case but I hope to hear from you guys have to say and whether it is really worth it. Cheers many thanks for the help in advanced.
https://linustechtips.com/topic/841915-upgrade-wifi-card/
why $15 a month? it should only be a 1 time expense
for the laptop, just grab a decent USB wireless adapter from amazon or newegg, usually they are soldered to the mainboard,, and difficult to remove
https://linustechtips.com/topic/841915-upgrade-wifi-card/#findComment-10508262
4 minutes ago, BubblyCharizard said:
for the laptop, usually they are soldered to the mainboard,, and difficult to remove
no they are not.
Wifi cards are almost never soldered unless you have some ultra thin piece of crap, and they are the next easiest thing to replace after storage and RAM.
https://linustechtips.com/topic/841915-upgrade-wifi-card/#findComment-10508285
It is what it is. If you want a wired connection, its +$15.
https://linustechtips.com/topic/841915-upgrade-wifi-card/#findComment-10508294
1 minute ago, *Chazz said:
Yes included in rent.
weird...I've not heard of that one before,
If you only use the laptop sat on a desk, I'd go with Ethernet any day of the week, you should get a better connection, but if you need mobility, then grab something like https://www.amazon.ca/Wireless-Adapter-AC600Mbps-Network-802-11ac/dp/B0727N25RL/ref=sr_1_1?ie=UTF8&qid=1507003215&sr=8-1&keywords=802.11ac+card
https://linustechtips.com/topic/841915-upgrade-wifi-card/#findComment-10508320
Daily drivers:
- HP Elite x2 1012 G2: Intel Core i7-7600U, Intel HD Graphics 620 + Aorus Gaming Box GTX 1080 eGPU, 16GB LPDDR3-1867, 256GB Toshiba NVMe PCIe 3.0 x4 SSD + 128GB Toshiba Exceria UHS-1 U3 MicroSD, 12.3" 2736x1824 + HP Pavilion 22cwa Monitor 21.5" 1080p IPS, Windows 10 Pro 64-bit
- LG V20 (H990DS): Qualcomm Snapdragon 820 (ARM-based), Adreno 530, 4GB LPDDR4, 64GB eMMC UFS 2.0 + 64GB SanDisk Extreme UHS-1 U3 V30 MicroSD, 5.7" IPS LCD 1440p + 2.1" 160x1040, Android 7.0 (LG UX 5.0)
Other devices:
- Lenovo IdeaPad Y400: Intel Core i7-3630QM, NVIDIA GeForce GT 750M SLI, 16GB DDR3-1600, 120GB Kingston mS200 mSATA SSD + 1TB HGST Travelstar 7K1000 7200rpm 2.5" HDD, 14" 768p, Windows 10 Pro 64-bit + Ubuntu 16.04 LTS 64-bit [retired]
- Dell Venue 11 Pro (7139): Intel Core i5-4300Y, Intel HD Graphics 4200, 8GB LPDDR3-1600, 256GB SanDisk X110 M.2 2260 SATA3 SSD, 10.8" 1080p IPS, Windows 10 Pro 64-bit + Ubuntu 16.04 LTS 64-bit [retired]
- Acer Iconia W4: Intel Atom Z3740, Intel HD Graphics, 2GB DDR3L-1033, 64GB Samsung MCG8GC eMMC, 8" IPS WXGA (1280x800), Windows 10 Home 32-bit
- Asus ZenFone 2 ZE551ML: Intel Atom Z3580 (x86-based), PowerVR G6430, 4GB LPDDR3, 64GB eMMC, 5.5" IPS LCD 1080p, Android 6.0.1 (Asus ZenUI)
- New Nintendo 2DS XL
https://linustechtips.com/topic/841915-upgrade-wifi-card/#findComment-10508502
Thanks you that's the kind answer I was I looking for. I need to buy a small screwdriver kit and I will open my laptop up and take a look at it. I suppose antenna wise that is not of any concern?
https://linustechtips.com/topic/841915-upgrade-wifi-card/#findComment-10512475
Antenna is always provided by the manufacturer for as it is used by the pre-installed WiFi card to make it work, so no worries on that. It should be easy to replace, just a matter of opening the laptop up, disconnect the AUX and MAIN cable (black and white cable) from the old card, take it out, and put the new one in while reconnecting the cables back.
Daily drivers:
Other devices:
https://linustechtips.com/topic/841915-upgrade-wifi-card/#findComment-10517252
I guess I draw my concern from the rc community. For FPV (First Person View) the usually use 5.8 for video transmission. However there are some that use 2.4 as well. The antennas are  distinctly different in size between 2.4 and 5.8. I suppose for laptops it is not as critical. I was really concerened that the card would work and everything, but have crappy signal with 5.8. I will go ahead and do it. I think I will try to post the outcomes later. I should have it done within the next week or so. Many thanks again.
https://linustechtips.com/topic/841915-upgrade-wifi-card/#findComment-10524352
