Snowball ice
Hi @Powesedor (Pedro Pereira)!
Sad to hear about your ModMic 4, we do have a 1 year warranty on it in case it was a defect that caused it to die!
So we often recommend using a USB interface with the ModMic because USB devices usually come with a built in noise filter. It would have solved your ModMic 4 problem and I'd be happy to throw one into your next purchase for free if you want to consider continuing on with the ModMic family.
That said, the Snowball will solve that problem without the adapter because it is a USB mic and that noise filter is built in. You just need an open USB port, no soundcard is required. Ideally don't put your mic on a USB hub, as that can add more noise.
Hope it helps, if you are interested in taking me up on the USB offer drop me a PM ![]()
