so i bought gta5 and downloaded the flash mod, the game runs fine but when i use the flash mod it lags
my specs:
Processor    Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz, 3601 Mhz, 4 Core(s), 8 Logical Processor(s)
Installed 16.0 GB RAM
GeforceGTX 1060 6GB
i do have directX 11 installed btw
plz help me
https://linustechtips.com/topic/834401-help-me-plz/
1 minute ago, ImperialSteele said:
RAM and CPU would be in task manager, and your GFX card should have software to give you a readout on it depending on the brand (MSI - Afterburner, Asus - GPU Tweak II, ect.)
cpu is 13 percent when im not using and memory is 29 when im not using
https://linustechtips.com/topic/834401-help-me-plz/#findComment-10428915
