I'm confused on what to do,
So I just got my internet package upgraded to 250/30
I'm getting around 200 wireless, but when I use my home plugs and connect through the mains of my house, which runs to my computer upstairs i'm only getting around 50mpbs, any reason why?
Can it be my computer?
Can it be my cables / plugs?
https://linustechtips.com/topic/834035-hey-i-need-some-help/
Often, you won't see the highest speeds through Powerline, especially if your adapters are far away from each other.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/834035-hey-i-need-some-help/#findComment-10424732
1 minute ago, George Nellist said:
They are really not that far from each other about 10 meters, When I go to look at my network status it only shows this http://prntscr.com/gkbo1t
should it be showing 1gbps ?
Your Powerline adapters likely only have 10/100 Mbps ports. That's pretty common. Can't you just use ethernet for that short of a distance?
Main System: Phobos
https://linustechtips.com/topic/834035-hey-i-need-some-help/#findComment-10424753
Just now, George Nellist said:
On my powerline adapters it says that they are 500 Mbps
Quote me when responding so I'll see your response. I've seen some advertised as 500 Mbps, but only have 10/100 ports. My Powerline adapters are like that.
Main System: Phobos
https://linustechtips.com/topic/834035-hey-i-need-some-help/#findComment-10424772
Are you in an older house with old cabling? Since you're using powerline, I've heard it's been bottlenecked by bad wiring.
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
https://linustechtips.com/topic/834035-hey-i-need-some-help/#findComment-10424783
13 minutes ago, George Nellist said:
@Jamiec1130 Is it able to make the ports unlimited
What do you mean?
Main System: Phobos
https://linustechtips.com/topic/834035-hey-i-need-some-help/#findComment-10424819
I have seen many of them hit 500+. They can hit it just dont cheap out on them and do research before. Like you said some have only fast ports.
No its physical limitation of the port
The cause might be bad wiring or the power lines run close to something causing interference such as anything electrical or if there is high amount of power running through a wire.
https://linustechtips.com/topic/834035-hey-i-need-some-help/#findComment-10424856
