I have this odd problem with my mouse, Where rightclicking sometimes either doesn't register or is considered a Double click.
I've only noticed this happening inside Dota 2. I was wondering if there is some kind of program or a easy way to test if it's my mouses faulth, or somehow The game is at faulth / some setting in the game is wrong?.
I haven't been able to track down the issue in the drivers of the mouse (I both upgraded my drivers and tried the 3 newest released to no avail) I really don't want to upen my mouse as i'm unsure how the pads underneath will react to it. Do any one have tips to what i should attemt to do?
https://linustechtips.com/topic/833463-roccat-tyon-double-click/
How old is your mouse? and how much have you been playing dota with it?
THis seems to be normal degredation. Meaning you have used it too much/it wasnt the best made piece and it started to malfunction a bit after time. Happened to me too on other mouses after time.
What to do? Warranty claim if you can, otherwise i am not sure you can do anything apart from getting a new mouse. (i might be wrong)
ASUS Maximus VII Hero | i7 4790K OC 4.8GHZ | 4x8GB 2400MHz MSI GTX 1070 alphacool eiswolf gpx pro
Samsung 850 EVO 520GB + Corsair 525gb + 275gb SSD  2TB Seagate Barracuda | 8TB Seagate Archive
Cooler Master HAF-X 942 | EVGA Supernova 1000W 80+ Platinum | Custom watercooling loop (gpu+cpu)
360mm+180mm rad and 10 fans | Swiftech D5 mcp655-B
About 1 1/2 or 2 years old now. Pretty much daily use. According to the tracker on the driver i have done a about 1.5m clicks on the mouse.
Is there any fix or anything i can try to do, or is the only option to grab a new mouse?
The weird thing is that i havent had any problem outside of dota. Atleast non that i have noticed.
warranty claim i think is a good idea, 1.5m clicks is nice but the mouse should withhold around 4m
