I'm configuring a custom loop right now for my planned Coffee Lake/Ryzen Rig, but I just can't seem to find a good case that can fit a 360mm Radiator with good pump mounting.
Any recommendations?
(Other than the Enthoo Evolv because that thing has terrible airflow)
|i7 4790k @ 4.4 GHz|Corsair H80i GT|Crappy MSI Z97 Gaming 5 w/ broken pins|ASUS Strix GTX 980|16 GB G.Skill Trident X @2400 Mhz|
|Zalman Z9 Neo|Generic Thermaltake 750W PSU|
I'm waiting for Coffee lake pls don't hurt me
https://linustechtips.com/topic/833305-best-cases-for-watercooling/
Thermaltake X9 its pretty good but expensive
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
The case looks good but I don't have the budget to utilize the full extent of the radiator support. I'll definitely think about it though.
I have a custom look in this case. It's fantastic, however a bit of creativity is required. Using acrylic to make extend the motherboard tray all the way across the case give a great mounting point for a res.
thermaltake has lots of cases that are compatible  with water cooling
1 minute ago, GT20Modding said:
Define S.
The case does look quite nice and has good pump mounting. I'll probably consider picking that up when the time is right.
I was thinking about that for a thermaltake V21 build I was planning
Yea, I came across some of their tempered glass cases and wanted to pick those up, but the price premium drove me away a little bit.
57 minutes ago, Damascus said:
Core P3 or P5 all the way
I loved the concept but I don't actually have the adequate space to put it where I live so I had to pass that. A damn good case though.
I was gonna get that one but bought a corsair 400c instead didnt have time to wait for case to ship from china. I have seen the Fractal design define S and its great. Very sturdy. BTW check out my youtube channel to see my build its GT20Modding just like forum
The P3 is barely larger than any other full atx case on the market and you could wall mount, unless you can't drill into the walls you should be fine
Want to custom loop?  Ask me more if you are curious
https://www.amazon.com/Thermaltake-Tempered-Certified-Pre-installed-CA-1H8-00M1WN-00/dp/B06XFWBNNB/ref=sr_1_21?s=pc&ie=UTF8&qid=1505076611&sr=1-21&keywords=case
Just now, Billy_Mays said:
Ahh, the non RGB version. That actually looks pretty good. Definitely will think about it.
