Hi Guys,
Quick question,
I'm looking at capture cards at the moment and I'm using a 144hz 1080p Monitor, do 1080p 60fps capture cards bottleneck the signal passing through? Or does it simply only CAPTURE at 60FPS while leaving the passthrough signal untouched and at the full 144fps? Do they increase any input lag to the monitor also?
Cheers, TFG
5950X @ 5.1ghz Perf Cores - 32GB 3966Mhz MHZ CL18 - WD SN850 Black 1TB x 2 - Gigabyte Eagle 3080 Ti (Bad Overclocker) - Corsair HX1000i
Lenovo Legion 7i 16ITHg6 - Intel i7 11800h 4.9Ghz Perf Cores - GTX 3070 8GB 2100Mhz - 32GB 3200Mhz CL18 - 1TB 980 Pro PCI-e 4.0 SSD - 2tb 970 EVO PCI-e 3.0 SSD
https://linustechtips.com/topic/831101-streaming-capture-card-question/
4 minutes ago, MVPernula said:
I'd like to know this too tbh
same
KRONOS:
// AMD FX 8350 // ASUS ROG CROSSHAIR V FORMULA Z // G.Skill Ripjaws 16GB 2x8 1866Mhz DDR3 // ASUS ROG STRIX GTX 1070 OC // CORSAIR SPEC-03 // Kingston SSD v300Now 120GB, 1TB WD Blue // Cooler Master V750 750W // 1x BENQ GL2760H 1080p 60hz 2ms // Corsair H75 CPU Cooler // Razer BlackWidow Ultimate Battlefeild 4 Collectors Edition\K70 RGB Lux Cherry RED // Razer Deathadder Chroma // Logitech G213 Speakers // ASUS ROG MARS GTX 760 X2 (Retired) // Windows 8.1
i've heard some word that if you want a display refresh rate above your capture card refresh rate that you need to have a multiple, like 120Hz. EDIT: to avoid tearing in the capture, should mention that.
that said, i'd be amazed if there's any card that can pass trough 120Hz.
Imagine the filesize..
I'm using a 120hz monitor anyway so thats ok (Just wrote 144hz for conformative purposes) I'm just not sure whether these capture cards repeat the signal, totally pass-through the signal and "observe" it, or splits it.
If this is the case then I would choose Software capture @ 60fps and deal with the added resource strain (Which would bring my frame rate down from around the 100fps mark) Or to just adopt the hardware restriction of 60fps.
Just to make it really clear, I do not want to CAPTURE at 120hz, I just don't want my 120hz signal that passes through the capture device to limit the monitor to 60fps.
11 minutes ago, MVPernula said:
But I mean.. With the CPU horsepower you have you should be able to crush any recording software?
OBS is great y'know. I use it all the time!
Play at 144, but record 60.
Looks like i'll be doing it that way, I just have a bit of a weird setup (6 monitors on 2 PC's using Synergy so it all controls as one, using network drives), and was hoping to use the 2nd PC as the Stream work horse, which made me look at the Hardware capture option.
The only other way I thought of doing it is using Steam Stream over network to the 2nd PC but I've never played with it so i'm not sure exactly how it works, i'll have to tinker today.
You can use 2 pc's for software recording also, how I'm not quite sure of however.
OH ok, must be some kind of server, client system, i'll look into it, cheers :)
