So I need to reset my computers admin's password. I am running windows 8.1 and I need to reset the admins password. Can someone help me with this because I want to be applicable to install applications without having to ask for rights.
Also please make it no-usb and no reset cause I am not going to do those.
Ok Thanks!!!
Edited by Glenwing
Caps lock removed from title
https://linustechtips.com/topic/829286-admin-password-help/
Ok Thanks!!!
 Try this: https://www.howtogeek.com/96630/how-to-reset-your-forgotten-windows-password-the-easy-way/
It works on Win 8.1 and 10 as well
https://linustechtips.com/topic/829286-admin-password-help/#findComment-10376952
Ok Thanks!!!
Windows R - syskey
Hi.
https://linustechtips.com/topic/829286-admin-password-help/#findComment-10376976
I agree with mynameisjuan. This sounds very fishy to me. Like you're trying to access somebody's else's computer. You want to be able to install applications without permission? You do realize info on hacking is not allowed here, right?
Best Excuses:
        #1(simple) "Well, I never liked that stupid thing anyway!"
        #2(complex) "Obviously there was a flaw in the material, probably due to the inadvertent introduction of contaminants during the manufacturing process."
https://linustechtips.com/topic/829286-admin-password-help/#findComment-10377039
Ok Thanks!!!
Press windows + R,
type in cmd
type in
systeminfo
send us the info
Hi.
https://linustechtips.com/topic/829286-admin-password-help/#findComment-10377049
Ok Thanks!!!
You can activate the built-in administrator account and use it to log in to your PC. Once logged in, change your target user to an administrator.
https://linustechtips.com/topic/829286-admin-password-help/#findComment-10378010
