Trouble With First Build!!!
Go to solution Solved by That_PC_Kid,
If you are using 32 bit Windows that could be the problem. 32 bit Windows only support up to 4GB of RAM while 64 bit support a lot more. However, it could be that your RAM isn't compatible with Ryzen.
I built this system two to three months ago and have had problems since day one. It stutters when starting programs and crashes whenever I try to game on it. So I sent my motherboard back to the manufaturer and they gave me a new one; The problem persisted. So I got Prime95 to see what the hell was going on. Whenever I stress tested the cpu on its own everything was fine but as soon as I added the RAM into the test cores started to fail. That didn't satisfy me so I went ahead and disabled SMT to see if that would fix anything, but again they kept failing. I went in search for some new RAM, Confident that it was the issue, I install it and my system doesn't post I get 3 beeps per DIMM and then 8 more beeps. I searched everywhere but no luck to what that means.
Should I just send The CPU back?
This is my system with the new RAM(Previous RAM was Corsair Vengeance LPX 2x4GB) https://pcpartpicker.com/user/jcoronado619/saved/j6RbvK
[PCPartPicker part list](https://pcpartpicker.com/list/knH6HN) / [Price breakdown by merchant](https://pcpartpicker.com/list/knH6HN/by_merchant/)
Type|Item|Price
**CPU** | [AMD - Ryzen 5 1600 3.2GHz 6-Core Processor](https://pcpartpicker.com/product/mV98TW/amd-ryzen-5-1600-32ghz-6-core-processor-yd1600bbaebox) | $209.99
**Motherboard** | [ASRock - AB350 Pro4 ATX AM4 Motherboard](https://pcpartpicker.com/product/yBtWGX/asrock-ab350-pro4-atx-am4-motherboard-ab350-pro4) | $93.77
**Memory** | [GeIL - EVO POTENZA 16GB (2 x 8GB) DDR4-3000 Memory](https://pcpartpicker.com/product/pH2rxr/geil-memory-gpr416gb3000c15adc) | $119.99
**Storage** | [Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive](https://pcpartpicker.com/product/MwW9TW/western-digital-internal-hard-drive-wd10ezex) | $49.99
**Video Card** | [MSI - GeForce GTX 1060 6GB 6GB GT OCV1 Video Card](https://pcpartpicker.com/product/TrGj4D/msi-geforce-gtx-1060-6gb-6gb-gt-ocv1-video-card-geforce-gtx-1060-6gt-ocv1) | $249.99
**Case** | [Deepcool - TESSERACT SW ATX Mid Tower Case](https://pcpartpicker.com/product/3MPfrH/deepcool-case-tesseractsw) | $39.99
**Power Supply** | [EVGA - SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply](https://pcpartpicker.com/product/g63RsY/evga-power-supply-120g10650xr) | $74.99
**Monitor** | [Asus - VE278Q 27.0" 1920x1080 Monitor](https://pcpartpicker.com/product/rTkD4D/asus-monitor-ve278q) | $189.99
**Keyboard** | [Thermaltake - CHALLENGER PRIME Wired Gaming Keyboard](https://pcpartpicker.com/product/6mPzK8/thermaltake-keyboard-kbchmmbblus01) | $59.99
**Headphones** | [Plantronics - RIG 500HD 7.1 Channel  Headset](https://pcpartpicker.com/product/7TJkcf/plantronics-headphones-rig500hd) | $67.99
 | *Prices include shipping, taxes, rebates, and discounts* |
 | **Total** | **$1156.68**
 | Generated by [PCPartPicker](http://pcpartpicker.com) 2017-08-23 20:21 EDT-0400 |
https://linustechtips.com/topic/826172-trouble-with-first-build/
