HELP!! Pc restarts constantly..
Go to solution Solved by MrDrWho13,
Reset CMOS and change CMOS battery. If that doesn't work, it's most likely the PSU since it happened so suddenly. If switching the PSU doesn't solve it, it's probably the motherboard. (at which point it's probably worth replacing the whole PC)
Hi guys,
So my dads internet browsing/youtube PC is acting up and I can't pin point it, maybe some of you know the symptoms better than I do.
When I turn on the pc it just restarts constantly and won't even boot into bios at all. I tried taking out the GPU and using onboard graphics, I reset the ram and even tried unplugging the boot drive to see if it would boot into BIOS.
Is this it? Is this the end of the motherboard? Or something else?? PSU?
Specs are:
GA87N-WIfi
G3258 (fairly new, about 1 year old)
GSKILL aegis ram 8gb (fairly new, About 1 year old)
240 GB Sandisk Plus SSD
The case is a Hadron Air with a integrated PSU.
Any help would be awesome!
https://linustechtips.com/topic/823195-help-pc-restarts-constantly/
5 minutes ago, Mouse-Potato said:
Hi guys,
Specs are:
GA87N-WIfi
You mean it goes into a restart cycle? Like non stop restart kind of thing? If yes, my friend had this issue and it was the PSU. Try changing the PSU.
PS. Provided you have restarted CMOS and the issue is still there.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
I edit my posts a lot.
Yes! It goes into a constant restart cycle, it just cycles through restart with a oud clicking noise. I took out the CMOS battery and going to try that.
I'm resetting CMOS atm but I was thinking about trying to wire a new PSU to the mobo and try to start it that way, is that a bad idea?
If you disconnect the current one from everything and then connect the new one then it should be fine.
