Hello, I recently reseseted my pc because it was slow and it deleted my graphics driver files and it doesn't let me play cs:go
So this is what happened
I launched csgo and it gave me a black screen for 3 seconds then this popped up https://gyazo.com/7a2e6c8270e2180de3458410a3c745af and then it told me to press "Ok" then when I pressed that it removed me from the game to "Online" state on steam.
My CPU is Amd and my graphics card is some next shitty Amd as well so it doesn't have onboard intel graphics...
https://linustechtips.com/topic/822497-help-with-problem-in-csgo/
Just now, Moeplazz said:
Yes I tried to do that but it's work, when I launch the exe file nothing happens and it also says that it's not compatible with windows 10?
Your drivers aren't compatible or CS:GO is not?
Well I was able to play csgo before but now it doesn't let me, I was able to play at like 60fps
Just reinstall CS. It's probably being bitchy.
That or just delete the exe file for it and make sure you clear any custom configs you have. Then use Steam's verify cache feature to redownload those.
I used to have a AMD graphics driver but now I don't but I'll try reinstalling csgo, haha
Hmm. Did you upgrade from an older OS or started with Windows 10?
my pc was windows 8.1 then I changed to windows 10 (the driver still worked) then after 1 year my pc became really slow so I resetted today and the lags was a bit less but csgo doesn't run like it used to which is annoying
Just now, Gamerguy207 said:
Reinstall csgo since it's a game saved to the steam cloud you won't lose any data
Thanks, I'll see if it works.
If you're using a GPU that doesn't have Windows 10 drivers, well you're kinda shit outta luck.
Only local files CS (and Dota and TF2) saves are config files so it really won't matter much :P
Try to use the integrated graphics just disable the gpu in the control panel if it is nvidia
Just now, Brinvasion said:
they normally do have graphics APU's are used for a good mix but AMD CPU's have integrated graphics depending on which one you have
I have a
AMD FX-6300 (really shitty one) does that have integrated graphics? I don't think it does
