1 minute ago, Ruffleduffle said:
i would go with the cx550 for the psu. you get better efficiency and when you want to upgrade later on you are less likely to need to buy a new psu.
tbh, every ddr4 ram is fine at this budget, go with whatever you can afford and at least 8gb of it. (you could scrape by with 4gb, but the expeirence will be terrible)
allthough two sticks of 4gb are better than 1 stick of 8gb
Edited by Ruffleduffle
I meaned to edit the post, sorry for the doubleup
https://linustechtips.com/topic/822073-i-ned-some-help/page/2/#findComment-10300915
i need a cheap good gaming motherboard that has DDR4 and 4 slots
https://linustechtips.com/topic/822073-i-ned-some-help/page/2/#findComment-10300928
Just now, KevinH9 said:
wait i though u can only run dual channel in 4 slots
it depends on the board, but usually in modern boards unless oyu need the slots for ridonculos amounts of ram i would go with higher capacity sticks in dual channel, thats where it usually is more cost-effective
https://linustechtips.com/topic/822073-i-ned-some-help/page/2/#findComment-10300964
https://www.newegg.com/Product/Product.aspx?Item=N82E16813157768&cm_re=ASROCK_Ryzen-_-13-157-768-_-Product is this a good board but i don't see a processor like clamp lock to keep it in the socket
https://linustechtips.com/topic/822073-i-ned-some-help/page/2/#findComment-10300969
the board is fine. The reason you dont see any clamp-like stuff that the am4 socket uses a pin-grid-arra and therefore no clamps are needen, the pins are hold in place in the socket itself
OH ok what about this board ASROCK A320M DGS MIRCO ATX AM4
https://linustechtips.com/topic/822073-i-ned-some-help/page/2/#findComment-10300983
3 hours ago, KevinH9 said:
Ok so a AMD RYZEN 3 Processor
And im gonna go with a MSI B350 TOMOHAWK motherboard
just a heads up with that motherboard.
the Tomahawk might come with an older Bios, which will prevent you from posting without a bios update. which would require a ryzen 7 processor to do. from what i understand the arctic version of that board doesnt have the same issue.
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/822073-i-ned-some-help/page/2/#findComment-10301711
