2 minutes ago, TXshooter said:
I have a mastercase pro 5 and im looking to upgrade. Should i use a corsair AIO cooler or should i use a custom loop from EKWB? If i do a custom loop, should i use soft or hard tubing?
Here is the upgrade list i have.
https://pcpartpicker.com/list/JmjfTH
I wouldn't recommend to watercooling it since the CPU is locked and the GPU doesn't dump out a particularly huge amount of heat.
-Moved to Liquid and Exotic Cooling-
Crap, wrong CPU, here is the right one.
https://pcpartpicker.com/list/CMRVpb
The corsair will be cheaper. What are your goals with watercooling?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
Im looking for overclocking on my cpu, i put a new link because i had the wrong cpu by the way. But mostly overclocking and style. Im doing it pretty much because i can
Unless you want to overclock to the extreme or add a GPU to your loop in the future (don't watercool your 1060), get the corsair.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
I want to overclock as much as i can. And im just getting the 1060 to start off, i plan on making upgrades later on but not for a while. I might get a 1080 instead of the 1060 but im not too sure.
As in you're willing to delid and pay an extra  $100-150 for a custom loop for an extra 100MHz, then by all means go custom loop. Otherwise, don't.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
If you plan to overclock the Corasir H100i would do well with it, for the Gtx 1060 though I wouldn't watercool it.
I just like the idea of a custom loop. The challenge appeals to me. Plus, i want performance on a budget, if i can do a custom loop and it be relevant, i will.
A custom loop is not something I would call performance on a budget, a proper CPU and GPU loop will start at around $500 USD, a bit less if you get the Fluid gaming series but there is no aluminum based full cover block for the gtx1060.
