I would recommend the likes of the G4560 or maybe something used if you are into that. Motherboard just get the cheapest B250. Again the cheapest 8GB DDR4 RAM kit will do and the cheapest Hard drive with the capacity you need. Either you stick with your GPU which will give you "alright" performance at 1080p or you try to sell it and go for a 1050 Ti or RX 470 (can't recommend that right now). Sticking with the RX 460 is your best bet right now.
https://linustechtips.com/topic/820810-newbie-building-pc-help/#findComment-10287337
37 minutes ago, Newbie02 said:
thank you so much friend now i have idea :)
Not sure if you have a HDD already, if you do then this build is within your budget and should last it for quote awhile. If you don't, get a R5 1400 and get a HDD
PCPartPicker part list: https://pcpartpicker.com/list/v44CYr
Price breakdown by merchant: https://pcpartpicker.com/list/v44CYr/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($197.88 @ OutletPC)
Motherboard: MSI - B350M PRO-VDH Micro ATX AM4 Motherboard  ($74.98 @ SuperBiiz)
Memory: Crucial - Ballistix Sport LT 8GB (1 x 8GB) DDR4-2400 Memory  ($59.99 @ Amazon)
Case: Cooler Master - MasterBox Lite 3.1 MicroATX Mid Tower Case  ($46.98 @ Newegg)
Total: $379.83
Generated by PCPartPicker 2017-08-11 23:35 EDT-0400
https://linustechtips.com/topic/820810-newbie-building-pc-help/#findComment-10287654
