Option 1: Figure out what applications are using it and stop them.
Option 2: Get an SSD or faster hard drive
My main computer:
i7 6700k || GTX 1070 || Asus Z170 RGB || C.M. Hyper 212 EVO || 16GB RAM || 256GB NVMe SSD || 500GB SATA SSD || 12TB total HDD || Define R5 Blackout || 850W PSU
More Details Below :)
CPU: Intel Core i7 6700k                             GPU:  EVGA GTX 1070 FTW                                  |  Motherboard: Asus Z170 Pro Gaming Aura
CPU Cooler: C.M. Hyper 212 EVO             RAM: 16GB Kingston Fury 4x4 DDR4 2400MHz         SSD:  Intel 256GB NVMe SSD & Plextor 500GB SATA SSD
Hard Drive:  WD 2TB Black, 2TB WD Blue, 8TB WD Red     Case:  Fractal Design Define R5 Blackout Edition   PSU:  Be Quiet! Dark Power Pro 11 850W
Additional Computer Parts: NZXT Hue for LEDs
Peripherals: Dell U2414H (x2) || Corsair Sabre RGB || Corsair K95 Platinum || Sennheiser 558's || Modmic
Pictures of setup:
https://linustechtips.com/topic/820632-hard-disk-problems/#findComment-10284871
4 minutes ago, BubblyCharizard said:
What processes are using the HDD?
Suggest putting the OS on an SSD (M.2 NVME if possible) and have the HDD only for games/file storage
5 minutes ago, stefanDB said:
start by defragmenting it. also, open up task manager to see if there is some kind of program that is using up all the capacity. if that doesn't help, get an SSD and install windows and other programs that you use often on that SSD.
the max i saw the usage in mb was 25 and that not 100% + it started after a stormy night
https://linustechtips.com/topic/820632-hard-disk-problems/#findComment-10284894
1 minute ago, stefanDB said:
if im not mistaken windows does have a utility to test hard drives, use that to see if it is damaged. if it is, you are just gonna have to replace it but you should probably try the other advice as well.
well the pc was unplugged from the wall  i was on it at the time so when i heard the first one i turned it off asap
https://linustechtips.com/topic/820632-hard-disk-problems/#findComment-10284917
here i send a screenshot
https://linustechtips.com/topic/820632-hard-disk-problems/#findComment-10284930
did you perform a clean shutdown, or just pull the plug (the latter can cause damage to components)
https://linustechtips.com/topic/820632-hard-disk-problems/#findComment-10284931
