i was having the same problem with my netgear wi-fi device. i tried contacting the isp and it helped..i suggest you contact you isp for the problem.
these are some usefull sites if you visit india..Rajasthan Tour IndiaLoan Against PropertyTaxi Services In Faridabad
https://linustechtips.com/topic/8198-wifi-problems/#findComment-96803
It sounds like it is too close to other routers on the same channel, try downloading wifi analyzer on the Google play store it can tell you what the proper channel is as long as your phones wifi can pick up the other wifi in the area,
sources: I work for an isp and have had to fix this issue for several customers.
Main rig: i7 4790k, Cooler H55, EVGA GTX 980, Corsair Obsidian 250D, ASRock H97M-ITX/ac, G.Skill 8GB, 500GB 840 EVO, 1TB WD Black
Server:  HP DL380 G5 8x 300GB 10k Sata drives, 2x e5460 32GB Ram
NAS: Synology DS213 with 2 2TB WD Red Drives
https://linustechtips.com/topic/8198-wifi-problems/#findComment-96897
