Bloody hell!! I over slept!! What did I miss?!?! O.o
Anyway, I'm looking at getting a network switch, one that can allow port prioritisation. For instance, streaming Wipeout Omega Collection on PS4, but prioritise my PC handle all the capture/streaming.
I have been looking at the Netgear Nighthawk, but I do get the feeling that this one would be rather overpriced for what I need.
What would you recommend?
Cheers and I'm sorry for my rather lengthy absence. :)
Phanteks Enthoo Evolv ATX | Intel Core i7 4790K 4.0Ghz | Asus Z97 PRO | Kingston HyperX Fury 32GB (4x 8GB) 1600Mhz | Noctua NH-D15 | EVGA SuperNova 850 G2 with CableMod Custom Sleeved Cables (Black/White) Samsung 850 EVO 250GB | Western Digital Caviar Black 2TB | Western Digital Blue Series 4TB | 3x Noctua NF-F12 PWM + 3x Noctua NF-A14 PWM | 2x EVGA GeForce GTX 970 4GB FTW+ ACX 2.0 in SLI | Windows 8.1 | Corsair K70 LUX RGB with Cherry MX Brown Switches | Logitech G502 Proteus Spectrum | Glorious PG Gaming Race Extended Mouse Mat | Beresford Caiman MKII DAC + Amptastic Mini-1 Stereo Amplifier + Q Acoustics 2010i | Sennheiser HD 598 | Audio Technica AT2020USB+ | Logitech C920 | Asus ROG Swift PG279Q
https://linustechtips.com/topic/818292-network-switches-advice/
bump...anyone there?
https://linustechtips.com/topic/818292-network-switches-advice/#findComment-10262746
Port prioritization? I don't know what exactly you are talking about...everything should work automatically. Why would you have to prioritize that traffic? I'm confused.
thebros35, out.
https://linustechtips.com/topic/818292-network-switches-advice/#findComment-10262805
I probably mean QoS.
https://linustechtips.com/topic/818292-network-switches-advice/#findComment-10262895
You'd need a L3 managed Switch for QoS or even a router. Those can be expensive
https://linustechtips.com/topic/818292-network-switches-advice/#findComment-10262916
OK, I was thinking that was what you meant. But you don't really need QoS... have you tried this setup without QoS? Usually that is just used for priotrizing data in a large enterprise with many different data streams of different media types. If you are just doing this at home, QoS is overkill from what I understand.
Someone please correct me if I'm wrong, I would like a second opinion as well.
thebros35, out.
https://linustechtips.com/topic/818292-network-switches-advice/#findComment-10262920
https://linustechtips.com/topic/818292-network-switches-advice/#findComment-10262961
43 minutes ago, ScarisRacer said:
I've got that one at home, been using it for about a year. Its basic and works just fine, I would get it.
thebros35, out.
https://linustechtips.com/topic/818292-network-switches-advice/#findComment-10263219
1 hour ago, ScarisRacer said:
It doesn't provide QoS.. It's an unmanaged switch.
QoS does help. If there are multiple people who are hogging the internet connection, everything will slow done and people will complain. If OP has bad internet or the equipment is bad then he/she will need to upgrade. Simple as.
https://linustechtips.com/topic/818292-network-switches-advice/#findComment-10263306
