Hey guys,
                  Made a new build a month ago installed windows 7 and had no issues whatsoever, the build is a ryzen 1600 build with 8gb hyper x 2400 mhz ram and a gigabyte ab 350 gaming motherboard with a rx 570 running on 3 hdds.The issue arose when i tried to upgrade to windows 10 . I tried to upgrade directly from windows 7 and ran into booting issues.Then i tried a clean install but was unable to do so because windows 10 always gives the same error " could not set the offline locale information. Error code 0x80ff0000." I dont know what the problem is i have scoured every forum and every thread that had the slightest mention of this issue.The installation media is not corrupt, the hdd is fine ,bios has been updated to the latest and still the error pops up at the same time when windows copies all files and starts to install features.I dont know what the problems is .I tried to install two different windows 10 versions one from disc and the other from usb drive and both show the same error at the same time.I tried installing both the version via the same media on my older fx 8350 chip on an asus m5a97 le r2.0 with the same hdds and both the versions installed without a hitch. Please help me i have no idea what is wrong.
https://linustechtips.com/topic/818171-need-help-no-idea-whats-wrong/
If you can, use DBAN to wipe your storage devices and then install windows 10 from scratch.
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
Update :i think it is a mobo issue my mobo still saves the date and time along with other settings when i remove the cmos battery and the psu cable the mobo resets only via  the jumper and then continues to save date and time with no cmos battery. What is this??? Never ran into a problem like this before????
6 minutes ago, Laban Lendup Sherpa said:
I have narrowed the problem to the bios.
Re-flash your motherboard?
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
